Old 04-10-2013, 12:49 PM
RicochetFord RicochetFord is offline
Question
Originally Posted by TommyK View Post
I think the width is the same for the 2. If you post a pic I can tell which rockshaft you have. I have both types of rockshafts at home, and i use the brake shoe pto on my 108.
You could always switch rockshafts, depending on which style pto you want to use. As long as you can get the rockshaft bushing off so you can remove the rockshaft from the frame.
I will have to look real close when I get home to figure out what I have. Wouldn't changing the rockshaft also require changing the clutch assembly as well if it was supposed to have the brake shoe? Are the rockshaft model specific between the 86, 108 ect.?
Is it a bad sign if the belt running from the clutch pulley down to the deck is not running straight. To clarify: if you stand beside the mower and look at the belt which is running vertically between the clutch and deck pulleys it appears that the clutch is too far forward.
I mowed with it for probably 20-30 minutes Monday and everything seemed fine it just looks off to me. I have been working on a fuel tank leak and trying to get the charging system to work and have not really investigated anything yet.
Old 04-10-2013, 02:51 PM
TommyK's Avatar
TommyK TommyK is offline
I measured the pto rockshaft arms, the non brake style rockshaft arm is one inch wide, the brake style rockshaft arm is 1.5 inches wide, so there is a difference. Does your pto clutch have a thrust button on it? Either way, i would leave your pto engaged, so that busted nut on your rockshaft doesn't contact your pto clutch. Hopefully all you need is a wear button for your rockshaft. Pics would help.
Here's the link for deck belt alignment in the technical section of the website.
http://www.onlycubcadets.net/forum/showthread.php?t=5
Old 04-10-2013, 06:39 PM
Attachment 35398
Here is the best picture I could get of the situation. From what I can tell I just need the wear button however the end of the rockshaft and one of the clutch fingers are damaged. The rockshaft measures one inch. I checked my serial against the PTO link and it falls into the type B clutch with out the brake assuming its OEM.
Old 04-10-2013, 06:44 PM
Attachment 35399
Here are some pictures of my new toy. Now I just need to figure out how to rotate pictures with my ipad!
Old 04-10-2013, 07:59 PM
Ouch my neck...
Looks good from here as for your pto looks like you need just the fiber button.
Fixed your pix
Old 04-10-2013, 09:07 PM
Nice looking 86!
Old 04-10-2013, 10:10 PM
Nice 86, you have there!
Old 04-10-2013, 10:27 PM
Nice 86! You will have fun with that tractor!
Old 04-10-2013, 11:15 PM
rweaver rweaver is offline
the brake parts some are nla or very expensive I just use the reg one with a button both arms are the same width the hole is the only change we have either arm or brake parts used
Old 04-10-2013, 11:17 PM
Thanks for the comments. I really just got the idea to get a Cub because I am an IHC fan. I have many memories around old 1066's, 806's even a 1466 with a turbo if I remember correctly. My first truck was an IDI 7.3 andI refuse to get rid of my Powerstroke 7.3.
I have been into old Honda motorcycles for years but when the kids came I decided to get into something I could do with them when they got older and bought a 66 Scout 800. It's still a work in progress but I have really enjoyed it so far. After three days I think the Cub will be another addiction. The old stuff impresses me because it was made in the U.S.A. And was made to last, not wear out so you come back to buy the same thing again. I call it my old iron habit.
