Old 02-24-2013, 07:00 PM
jmroy's Avatar
jmroy jmroy is offline
An easier way to get at those roll pins in a narrow frame is to remove the roll pin at the other end of the drive shaft so you can slide off the two pressure plates and the clutch disk. Then you can disconnect the brake, unbolt the transaxle, and then split the transaxle from the rest of the tractor. The drive shaft will slide out with it and then you can work on removing those roll pins without being confined to the small space between the frame rails.
To remove that one roll pin lock the clutch pedal down, then brace up the end of the drive shaft and drive it out. Much easier than working under the tractor.
Web Developer - Need a website? Contact me.
Old 02-24-2013, 07:38 PM
vartz04 vartz04 is offline
Tractor is flipped upside down
Cub 104 Refurbed Sprinig of 2013
Aftermarket headlights, 3 point, Brinly Adapter, Spring Assist, 42" IH Blade, 42" Mower Deck, 42" Craftsman Grader Blade, 10" Brinly Plow, 6-12 ags and 22x9.50 turfs
Old 02-24-2013, 08:13 PM
cubfixer's Avatar
cubfixer cubfixer is offline
I had one stuck on my 100. Tried everything. Then drilled a 1/2 inch hole in the tunnel above the pin. Took a bottle jack and took up the slack below the coupler. Took a pilot punch (has a nipple on the end that goes in the hole in a roll pin). And with a fairly long pilot punch was able to drive down on the pin to drive it through.
John
Old 02-24-2013, 08:41 PM
[QUOTE=Yosemite Sam;176259]It may sound silly, but go to Sears and get a package of roll/spiral pin punches, they should cost you aboul $20.00=QUOTE]
I've got the same set Yosemite Sam,red is easy to find ...
Old 02-24-2013, 10:03 PM
LMAO!!!
As much as I hate to admit it, I have a 147 that has been giving me trouble, rolled over on it's side and propped up with a couple of "spare" wheels and tires.
Old 02-24-2013, 10:23 PM
Well mine is just the frame and the axle now. It's all taken apart for paint. Not sure I would do it full of fluids. Hopefully I remember to refill the rearend when I am done with this project.
Old 03-01-2013, 09:11 AM
Still no luck using the punches and having wood jammed in there to hold it. Is it possible to drill these out?
Old 03-01-2013, 09:36 AM
You may want to take a grinder and smooth out the area you have been pounding on on the coupler/spirol pin. That way you can get an idea where the center of the pin is and clear up any "mushrooming" of the area.
Just a thought
Old 03-01-2013, 09:39 AM
garrynok's Avatar
garrynok garrynok is offline
Looks like the ends of the pins have become flared making them larger in diameter than the hole they are in. You might try taking a dremel tool and whacking the pin off flush with the rockshaft then driving it out with a roll pin punch. .....humm...how would I know this?
Garry
Old 03-01-2013, 10:17 AM
Are these 1 way in 1 way out? I've been working on the one end that is below the collar so it isn't mushroomed. I got new wheels for my cut off tool yesterday so maybe ill have to do some chopping. Those roll pin punches weren't cheap. Made about 60 miles from my house though
