-   -   options if pins wont come out of drive shaft (rear end side) (https://www.onlycubcadets.net/forum/showthread.php?t=22866)
vartz04 02-24-2013 02:20 PM
I can't get these things out. Not with heat or oil or a bfh. Any other ideas. I'm okay with destroying the shaft if need be. Here's a pic of what I'm talkin about http://i7.photobucket.com/albums/y27...ps0288432a.jpg
This is on a 104
zolf12 02-24-2013 02:43 PM
I just did this the other night I was having problems too. My first problem was I didn't having enough space to swing my hammer to hit the punch to drive the pin out. But just as important is having the right size punch. Only use a 1/4" punch. I was using a 3/16" and I was causing more damage by peening over the end that you want to drive out of hole making more thinks worse. Go over to Lowes cost $12 for a 6 piece set made by Bostich. Don't forget to shoot some P.B.Blaster on the pin before leave for the store.
Good Luck
Jeff
Yosemite Sam 02-24-2013 02:47 PM
It may sound silly, but go to Sears and get a package of roll/spiral pin punches, they should cost you aboul $20.00
Then, using a grinder or cut off wheel, grind/cut the pin flush with the side of the coupler. Using your new 1/4" punch, drive the pin out! Don't mess around with it, just DRIVE it out.
You also may want to cut a piece of wood that you can wedge between the coupler and the under side of the tunnel to give the input shaft some support, it will not only help protect the input shaft/bearing/housing from damage, it will also make each "wack" with your hammer more productive.
vartz04 02-24-2013 03:00 PM
I have punches. I'm going to have to chop em flush and try the wood trick too. I'm gonna see if my dad has a longer one though.
Jumper 02-24-2013 03:44 PM
vartz04: The roll pin punch MAKES A BIG DIFFERENCE, believe us, we know from painful experience. :Rant::Swear::Unknown:
restore49 02-24-2013 03:48 PM
roll/ Spiral punch ONLY - and brace.
Yosemite Sam 02-24-2013 03:53 PM
I can NOT express how much I agree with Jumper. Thanks for the pic.
ihcc104 02-24-2013 04:20 PM
Spirol punches are the way to go!!! They make quick work of taking out those pins! I agree with everyone else! :beerchug:
vartz04 02-24-2013 04:21 PM
Thanks guys. I'll get some of those.
Yosemite Sam 02-24-2013 04:30 PM
I promise you won't regret it.
