Old 08-26-2012, 07:41 AM
cdlong's Avatar
cdlong cdlong is offline
Switch is bad. I have power to the round terminal on the switch base, but not to the spade,(back side of switch is really rusted, wire brush didn't help). I also found the hydraulic lift lever is moving, but the shaft isn't moving the lever to the hydraulic valve. (Nice having a 2nd working 1450 to compare with). Guess the steering rebuild will happen sooner than later since I have to remove the dash tower to troubleshoot the hydraulics. Both 1450s have the same amount of axle "wiggle" front to rear, so I'm figuring this is normal.
Papaw
1984 CCC 582 w/ creeper, 42" blade, 44C deck, 220# wheel weights, 2 link chains & adjusters, Spring assist lift.
Old 08-26-2012, 08:52 AM
cdlong's Avatar
Spiral pin in hydraulic lift handle was sheared. Any one know what size pin I need? (5/16ths). Thank God for Sears hardware stores! I have got to build a shed. Running out of driveway!
Papaw
Old 08-26-2012, 09:20 AM
teejk teejk is offline
did you bypass the brake switch? might explain why no power to the other side of the solenoid. otherwise it might be the switch (my 1250 eats them like popcorn).
Old 08-26-2012, 10:11 AM
It would be worth your time to figure out why...it's obviously not supposed to be going through switches like that.
Old 08-26-2012, 10:29 AM
cdlong's Avatar
I haven't by-passed anything. Just repairing what I've found wrong. Hydraulics are repaired.
Papaw
Old 08-26-2012, 10:49 AM
I figure they are just crappy switches Matt (I get them from the dealer but they obviously aren't IH). They corrode quickly. I can guess it's always been that way (I got it 8 years old and until I read it here I didn't realize there was a "quick connect"...mine is a series of loose pigtails.
Old 08-26-2012, 03:26 PM
Mike1450's Avatar
Mike1450 Mike1450 is offline
Cdlong
Two safety switches need to work before the starter will turn. One is the brake switch (activated by a metal tab which brakes off some times) and Two the PTO switch itself.
Old 08-26-2012, 05:11 PM
other than being a big PITA to get at, I would jumper out the brake switch first. that thing is subject to all the junk (and as you point out, that little "paddle" that activates the switch is a "maintenance" item). my 1250's PTO switch is original but it sits high and apparently is not subject to much abuse. I squirt some WD40 in once and a while anyway.
Old 08-27-2012, 03:54 AM
cdlong's Avatar
Ignition switch was bad. Got a new one @ Tractor supply, but the terminals are different. Had to make m x fm spade jumpers to get correct terminals from switch to wiring harness. Tonight I'll ry to get the steering box out.
Papaw
Old 08-27-2012, 07:43 PM
cdlong's Avatar
Ordered steering upgrade kits and seals & seal retainers today. Both steering columns are out. Leaned a lesson, don't remove the hydraulic valve body. Need to replace the wheel bearing on newest 1450. Cam follower wasn't even tight. I'll use medium Loc-Tite on reassembly.
Papaw
