![]() Quote:
DWayne 1973: 128, ag tires, 3pt. lift, spring assist, lights, 42" Deck 10" moldboard plow 2016 XT1 42" deck 18HP |
Last time I worked on this engine, as I recall, one of the grease/oil seals on the crankshaft went on what I thought was loose feeling.
Its on the flywheel end of the crank. I believe it slid on with just pushing with a couple screwdrivers down into the groove for it. I don't think its the right seal. I need to take that off and get that fixed before going any further. No need to put it back together and have to take it apart again. Its a seal that came with the overhaul kit. Could be I used the wrong one, but there were only two that looked alike. Dave |
Good to get that sorted out before going further. If you can post a pic, I'm sure one of the gurus here can help you from going bad .
It seems a digital camera is one of the most important Cub tools ...and a membership in this forum. Matt, Duke, Allen, Lew and all the others will get you going in the right direction. We in the peanut gallery can help provide motivation ! :-) John
![]() Quote:
![]() We like to use little hints that we like ![]() |
I'll try to get a picture on here. Looks like its all rubber, been a long time since I put it in there, but as I recall it went in too easy.
It should have a metal shoulder. You may have to use some red sealant to hold it in or, go buy a Kohler brand seal. I think some of the aftermarket brand seals don't quite meet the Kohler specs.
Here are the numbers on the side of the engine.
K321A S/N 6234979 Spec No. 60166d I suspect this could be a local Oreilly Auto parts item if I can cross reference it. Dave |
I'am thinking Napa Auto might have that part too, or any of the site sponsers, and your local CC dealer man.
IH CUB CADET 1450, 72, 86, 1211, IH #2 CART, IH 56" SNOW BLADE, COLLECTING CUB CADET ENGINES |
Like everyone else has said, Im watching you!
![]() ![]() Everyday im messing with my 1450 just to get it to do a minimum of one engine revolution under its own power but i havent kicked it in the pants hard enough i guess ![]()
1967 IH Cub Cadet 123 1978 IH Cub Cadet 1650 19?? IH Cub Cadet 682 |
Dave R,
These guys have inspired me a lot! I am one of the best procrastinators on the planet too. Try to just go work on it for 15 minutes. That sometimes turns into a hour and shows some movement to the project. If you can get a heater to warm up the work area that can mean a lot this time of year. Write a to do list and chip at it a little each day. You will get back in the groove. And we are watching! I have to go get some more peanuts, this should be good! Regards, Chris
Casbohm Maple and Honey www.mapleandhoney.com Cubs: 147R and the "train", 127 elec lift, 127, 125, 106, 102, 100, 86, 73, Brinly plow, Snow thrower, 2 Rototillers, several mower decks and several snow plows, #1 cart, Grandkids barrel cart. |
