Old 08-03-2011, 01:27 PM
cubs-n-bxrs's Avatar
gillis51 a lot of times that so called gunk will be down both of the axle tubes and almost impossible to get to without removing the axle shafts and seals. I have had good luck wadding up a rag soaked in kerosene and poking into the axle tube with a piece of wooden dowel rod and pulling it out past the center carrier and keep doing that till the rag comes out reasonably clean. I always remove the pick up tube and blow it out with compressed air. Or you can remove the axle tubes to clean which means splitting the tractor. A lot of work the second option.
