Old 06-21-2011, 08:56 AM
Originally Posted by IWL BCNU View Post
Thanks, looks like the clutch parts will cost more than the tractor did.
But the good news is, they are all still available.
Old 06-30-2011, 08:31 PM
IWL BCNU IWL BCNU is offline
Okay, clutch is apart. Left side ISO bushings were gone and my 3 pin flange had the whole center knocked out. My shaft looks great, the drive flange w/ the slots does have just a tad of wear in the slots, should that be replaced? Both flanges have no grooves and look good, but will be faced. The throw out lever does have 2 grooves in it, can the be welded and reground? This will only be used for mowing, how much of the assembly should be replaced? I know the 3 pin flange, disc, and throwout bearing. Just not wanting to go overboard.
Thanks
Cub Cadet 1200
A "Few" David Bradleys
Sears Suburbans
Older John Deeres
Couple Gravelys
I think it's called ADD
Old 06-30-2011, 11:47 PM
rpage83 rpage83 is offline
Not sure on the other items, but I fixed my throwout bearing. Drilled a 1/16 size hole and filled the bearings with grease using a grease zert, nylon nut, and a hyperdermic needle. Not sure if it will be as good as a new one, but saved some time and was fun to try.
Dont do what I did with the clutch friction plates and not truly resurface and dont use the existing friction disk.
Good Luck!
Old 07-01-2011, 06:37 AM
My clutch shows little wear and in great shape except that the 3 bolt flange broke and wore out the holes in the disc. That flange is very thin metal, and I really hate to go back with it, but really don't have a choice it looks like.
Cub Cadet 1200
Sears Suburbans
Older John Deeres
Couple Gravelys
