Old 10-25-2011, 07:51 PM
73CC108's Avatar
73CC108 73CC108 is offline
Looking Good. Cant Wait To See It Done.
Old 10-25-2011, 07:57 PM
Todd that is part of the face lift! I've never had bear meat before but my wife is as mean as one! Ok maybe she's a cuddly as a baby bear.
Old 10-25-2011, 10:12 PM
Better watch it, buddy!
Old 10-25-2011, 10:16 PM
LarryW's Avatar
LarryW LarryW is offline
If the bear was young, you could have been eating a cub and working on one too, lol.
Nice work. Are you using any chemicals in taking the paint of or just the wire wheel?
Cub Cadet 147 2050041u340160
Cub cadet 129 main mower
Cub Cadet 1811
Old 10-26-2011, 12:59 PM
So far just the wire wheel. But I'm thinking of using some stripper sparingly. Keeping away from the gaskets. At least to get some of it off.
Old 10-27-2011, 09:16 PM
Heh, look what I found tonight when I took the rearend cover off to drain the fluid!
I've checked each gear for a missing piece, nothing. So I don't know if the PO had a problem and fixed it or what, but nothing seems to be broken.
The fluid, and inside looked very clean, so it may have been changed as a new gear was installed, only the PO would know I guess.
Old 10-27-2011, 09:25 PM
Hope your Cub won't need "dentures" soon.
Better to find it now than after it gets hung in the spiders!
Old 10-27-2011, 09:30 PM
bocephus1991's Avatar
Your resto/clean-up is looking great! If it were me I'd double check and triple check the rear end,its easy to miss the obvious sometimes as for cleaning up the rear what I did on my 1200 was wire wheel the devil out of it and use one of those soft spongy sanding pads to clean it up then primed it. Your doing a great job , keep it up!
Brian
Old 10-27-2011, 10:51 PM
Glad you found it, before damage was done, Todd.
Old 10-27-2011, 11:13 PM
johncub7172's Avatar
Looking great! Thanks for sharing! I have me a 72 that has been under cover about 16 years now,.... . The broken tooth would have me looking real good.
