Old 10-08-2011, 10:35 AM
The name,
CAD-Tr Model 6
came from the machine being designed to Transform do at least 6 different things.
Old 10-08-2011, 12:15 PM
red211's Avatar
red211 red211 is offline
I was going to make a log splitter to go on the cub, thinking a mounted one on a sleeve hitch run off the cub, either split from hydro or a pump run off the back of the engine. I found a 20 ton used for a good price so I will just pull it around with the cub instead. I still like the idea of one on the back, but I am betting it would be way to slow moving the cub around instead of rolling the wood to it.
How well does that splitter work? I am looking for faster ram speeds, that is the biggest problem I have with most splitters, too slow.
Old 10-08-2011, 09:29 PM
That is pretty cool!
Old 10-08-2011, 09:43 PM
When starting this machine I felt the most I would use a woodsplitter would be 5 days a year, if it was going to take up space it had to do something on some of those other 360 days!!
The CAD-Tr Model 6 has a slot on the end so attachments can be replaced by simply pulling a pin.
The slot accepts a piece of 1x8 hot rolled steel bar. Anything I can make out of or weld to the 1x8 steel bar can become an attachment for the Model 6.
The first attachment was the heavy wall tube (1/2" thick) shown in a previous post, to remove a shaft from a bearing or as noted could compress a Cub Cadet clutch spring!!
The second attachment I made was a 2 stage splitting wedge which will split wood into 3 pieces with each stroke.
A 3-way wedge makes quick work of oak firewood.
Now I need recommendations as to what attachment to make next, any recommendations??
Old 10-08-2011, 09:51 PM
LarryW's Avatar
LarryW LarryW is offline
So what 6 things will it do?-------nevermind, we posted at the same time, lol
That is cool! Awesome idea and great build. Looks great!
As for fast wood splitting, it reminded me of this video.
http://www.youtube.com/watch?v=2bVAAx3mMKY
Cub Cadet 147 2050041u340160
42" Mower Deck, Snow Thrower, Tire Chains and Weights, Rotary Tiller 1, Brinly Sleeve Hitch, Brinly 10" plow, Johnny Bucket Jr.,42" QA NF Dozer Blade.
Cub Cadet 1872 SGT
60" CCC deck.
Parts 129 future plans =ported pump for 147, cast iron rear for 1872,129 frame and steering axle= ?wagon?
