Old 09-28-2011, 08:52 PM
ihnick's Avatar
ihnick ihnick is offline
Default starter/crankshaft pulley
im having troubles keeping my starter pully on my 169 tight. i lock tighted both set screws with medium (blue) locktite and that didnt work either.
So do i need to stack set screws on top of each other or would it work to get a longer square key and tap it back so it goes up the ramp part of the crank shaft groove so it tightens? what do you guys think? THANKS
Nick.
Old 09-29-2011, 05:54 AM
Vince_o Vince_o is offline
Nick
On another board, a member had the same problem with one of his. I forget what he used. I will say that Ive pulled a few of those pto/ starter pulleys and some are real loose and others are nice and tight. I'm thinking that if they don't fit snug, maybe they rattle on the crank working the set screws loose.
Just thinking here
Old 09-29-2011, 07:13 AM
scleve scleve is offline
I have in the past used a square key that I beveled to tighten a pulley. I like the idea of stacking the set screws too. How much play is there between pulley and crank shaft? Do you need to use some shim stock?
O _____ O 27670 O 38245 O 49448 100 _____
All W/Fenders, 3 Point, Lights, Brinly Adapter
124 ______ 106 ______ 107 _______ 127 _______
All W/Hydro, 3 Point, Lights, Brinly Adapter
108 _______ W/Factory Electric Lift, 42" Blade, Brinly Adapter
109 _______ W/Factory Electric Lift, 1A Tiller Both/Ext
2 10" plows, Dbl Disk Harrow, Spring Tth Harrow, 2 42" Tool Bars, Box Blade, Yard Sweeper, Aerator 3 Sets Wh wts., Dethatcher, Garden Cart, York Rake(in pieces), Ect...
Old 09-29-2011, 09:07 AM
ihnick's Avatar
I can tighten the pulley up but then it rattles loose a little bit
Nick.
