Old 09-09-2011, 05:35 PM
only1stegall's Avatar
only1stegall only1stegall is offline
Default a few questions about my 149.... whats this lever for? pics..
hey guys...
got a few questions about my 149...
- whats this lever on the trans tunnel for?
- whats the lifting capacity on the sleve hitch/stock hydrulic system ? How much weight can I hang on my plow? (i repaired the bent lift arms last night, gave it all a coat of paint and added some new grade 8 hardware...
- the little plastic fan on the driveshaft... how important is it? it was fine the other day, but while I was plowing today it must have broken from vibration.. maybe it was brittle? idk... I made a pass and came back and there were peices of it in the dirt...
lastly, i spent about 30 mins plowing the garden up today... ive still got a little okra coming, but man i couldnt be happer with this little tractor!! Now I need a turn plow, a box scrape, a set of discs, and a tiller!!! haha!
thanks in advance guys!
Old 09-09-2011, 05:48 PM
The lever on the side of the tunnel cover is used to release the manual hydro valves so that you can push your tractor around if needed. You might want to remove the tunnel and see if you have manual or automatic valves. Each of the manual valves will have a button on top to push down. The auto valves will have nothing.
The limit of the rear lift I want to say is @ 300lbs. but I am not 100% sure about that. Someone here will know for sure. The fan is needed to help cool the hydro pump. The pump is aluminum with cooling fins on top and the fan blows air over the fins to aid in cooling of the hydro fluid. In my opinion I would put a new fan on before doing a lot of plowing or working the 149.
Old 09-09-2011, 05:51 PM
where can I buy that little fan? i wish i know why it broke?? it should be aluminum. plastic sucks!
mowing LT1045, plowing 149, tilling 149, parts 149...
plows, harrows, cultivators, box blade, tillers...
I like fast cars, big trucks, and yellow tractors!
My photo album
Old 09-09-2011, 05:57 PM
They used aluminum in the early model cubs but went plastic. It probably broke because of the age and it was brittle. If you think about it, it was over 30 years old before it broke... That's pretty dang good, LOL. You can pick one up at your local dealer or our sponsors up at the top of the page will have one. Also since you will have your drive shaft out, I would go ahead and put in new flex joints too. Then your drive shaft should be good for many more years as long as none of the spiral pin holes look worn. You do have the service manual for the 149? If not it is located in our GT library.
Service Manual: http://www.onlycubcadets.net/forum/s...ead.php?t=4644
Old 09-09-2011, 06:18 PM
Not familar with your 149, but you might want to look @ the lift arm to see if it is hitting the fan when lifting/dropping, while you have the tunnel cover off.
I've heard of them getting broken because the lift arm hits them.
Old 09-09-2011, 06:39 PM
You don't need to hang ANY weight on the plow...if you do, you have it adjusted wrong.
Old 09-09-2011, 09:03 PM
matt,
im not useing a turning plow... its some sort of cultivator plow.. it weighs maybe 50 pounds? and its short so i dont have leverage on my side.. if you think you can adjust it to dig in hard packed dirt with no weight please come educate me....
if you dont need weight why did you put a huge weight on that turning plow you restored? do you have it out of adjustment?
My photo album
ill check that in the AM... it just seems strange how it broke just all of a sudden. thanks!
My photo album
Old 09-09-2011, 09:21 PM
cubs-n-bxrs's Avatar
Originally Posted by only1stegall View Post
matt,
That would be a gauge wheel and not a weight my friend.
Old 09-09-2011, 09:26 PM
Correct.
only1stegall-
You said you had a plow, not a cultivator, so how was I supposed to know what you meant? Yeah, a cultivator is probably going to need some weight. The 3-point and sleeve hitch are probably good for ~250# safely, but you won't need that much for a cultivator.
