Been trying to get my 1250 running for the last week. Was mowing with it and it started running rough, in high throttle. Have tried another carb, tank filter, new gas, new plug, new points (has good spark), and new coil. Still runs rough, and will only run for short time.........
![]() ![]() Any suggestions? ![]() ![]()
-105___ Tiller |
Did you try changing each item out one at a time? It still sounds like a carb issue, dirt possibly or stuck float? Just a couple of ideas, I hate trouble shooting, LOL.
How about plug wire? I've had more than one that the end fit loosely on the end of the plug, and it would misfire. Squeeze it a bit with pliers if it's loose.
What do you mean short time? Runs rough for a short time or stops running after a short time? If stops running it could be coil or exhaust valve sticking.
![]() Quote:
The carb was leaking, so I adjusted the float, now its not leaking and seems to have plenty of fuel in it. ![]() And I hate trouble shooting, also! ![]() ![]()
-105___ Tiller |
![]() Quote:
Yes, I do remember it being very easy to pull of, very loose. Will have to try that! ![]()
-105___ Tiller |
![]() Quote:
It will run rough for a couple seconds....then die. ![]() Already have tried a new coil, but might look into the valve. ![]()
-105___ Tiller |
