Old 07-31-2011, 03:31 PM
J.Kauppila J.Kauppila is offline
Default 125 hydro rear axle leak
I have hydro fluid leaking out the end of the right rear axle, dripping down onto the wheel. This has developed recently.
Any suggestions on needed repairs?
Thanks,
Jim K.
Old 07-31-2011, 03:49 PM
Donovan M.'s Avatar
you need to change your axle seal.
Donovan:
62' Original-fenders
Old 07-31-2011, 04:33 PM
TEET's Avatar
TEET TEET is offline
You need to drain the rear of hytran, remove the snap ring from the affected axle at the pinion, slide out the axle, replace the seal, and reverse the order...refill with hytran. Its not a difficult job.
Here is the service manual for reference.
Jeff (teet)
CCC 1211
71
127
102
122
1962 Original
Old 07-31-2011, 05:55 PM
scleve scleve is offline
I just got through with the axel on my 106 and it was fairly easy. Just becareful putting in the new seal.
Old 07-31-2011, 07:44 PM
CC1650Dave's Avatar
I just did it last week, it's a pretty easy job. I have pics and such in the 1650 project thread at page 19, if you want to see mine.
Old 07-31-2011, 08:17 PM
Dave fyi posting page numbers might not work if someone has changed the default style. I view all threads with 40 post per page were the default is 10 post per page. A post range (19 - 23) or the actual post number if the info is just one post and not several post.
Old 07-31-2011, 08:58 PM
CC1650Dave's Avatar
ah yeah, good point.
Old 08-02-2011, 08:05 PM
Thanks for the help.
Any suggestions on where to buy the axle seal?
Jim K.
Old 08-02-2011, 08:47 PM
You can order from one of the sponsors or some people have crossed them with NAPA seals.
Old 08-02-2011, 10:02 PM
Napa # is 9878
Up to 534 and counting...
