Old 08-01-2011, 07:04 PM
Duncan10072 Duncan10072 is offline
Default Steering gear commonality
Met a guy who needs a steering column for his CC100. I have 3 or 4 that came with a bunch of parts that I bought, my question is, are all the narrow frame ones the same and the wide frames the same or all they all the same for all of them except the original. I am going to look it up in the parts books tomorrow, but thought someone would know off the top of thier head. Thanks
Rod
Old 08-01-2011, 07:11 PM
Donovan M.'s Avatar
mesure them the shorter ones are narrow frame and the longer ones are for wide frame.
Donovan:
62' Original-fenders
Old 08-01-2011, 07:13 PM
cub cadet people II's Avatar
cub cadet people II cub cadet people II is offline
They are all the same except the original is different, the only difference is if you put a replacement column in it will be taller. If you put a original replacement back in it will be the same length.
Mike
Way too many!: 4 digit Original’s #1218 and #8820, 70, 71, 72 x2, 73, 86, 100, RESTORED 102,105,122,123,124,125,147 with Danco Loader, 149, 1000, 1572 Diesel with 3 pt, (2) 42” snowplows, 54” Haban Power Angle Blade, (2) 38” decks, (2) 44” decks, (2) 48”decks, #1 cart, #2 cart, #3 cart, #4 cart, Brinly Moldboard plow, Brinly Cultivator, Brinly Disc Harrow,3 sets of IH wheel weights, IH Windbreaker Cab, QA36A blower, QA36 Blower,Boxblade, Giant Vac System off a 73!
Old 08-01-2011, 07:25 PM
I think there are at least 3 or 4 different lengths from 70 to 82 series. A 100 has a longer steering column than a 104, and both are NF tractors. I'm also fairly certain the 1x8/9/QL and 82 series are different, and different from either the 70/71/72/73/100 and the other NF models...
Old 08-01-2011, 08:44 PM
Thanks everyone, I measured and I have 2 different lengths, and the narrow frame one is shorter and has like a collar around the top of it. Now I can help another new CC100 owner. He is new to the addition and I just want to help him out. I told him about this website so hopefully he will join soon. Thanks again for everyone's help
Rod
