Old 07-23-2011, 08:52 PM
Duncan10072 Duncan10072 is offline
Default Picked up a 1450 today
Found a 1450 on craiglist and picked it up today. It is not a peach, but it runs like a top. Sorry, no pictures as wife is away with the camera for a couple of weeks. That makes it easier to haul these things home. Anyway, the 1450 has rear lift, IH wheel weights, nice 44" deck that works good, 54" front blade, 10" Brinly plow and a Brinly cultivator. Also have the sleeve hitch, new carb kit, and new rear diff cover gasket. Now for the bad, it has sat out for a while, needs front tires, choke cable is broke, screws broke off on the carb for holding on the aircleaner and the iso mounts are bad. Suprising after seeing it, how good it run and it is really pretty tight. Probably going to replace the iso mounts and fix a few small things and then sell the tractor/mower/front blade. I will keep the plow, cultivator, rear hitch, wheel weights and brinly hitch. It will make a good solid mower tractor, but I don't really have room to keep another one. Who know, once I get it fixed up a little, I may decide to keep it, that is what has happened with the other 20 of them that I have. I will try to post pictures when my wife gets back in a couple of weeks.
Rod
Old 07-23-2011, 08:57 PM
Thats the way it goes with cubs,next thing you know you have 21
Old 07-23-2011, 10:40 PM
Well said and once you get to 21 then you start trying to keep up with Lew and Mike!
Old 07-23-2011, 10:56 PM
Congrats on your 1450!
Old 07-23-2011, 11:22 PM
Duncan10072
I agree, you might just end up keeping it
Old 07-24-2011, 08:35 AM
Congrats on the 1450 Rod!
Can't wait to see the pics!
Good one Duke!
