Does anyone know if the 128 has adjustments for cutting height?
Hey guys, I finally got back to the barn and pulled out the tractor. The old Kholer started up after I "cleaned the carb" float was stuck open. Ran rather well with some new gas and an oil change. Looks like I need two new front tires (size ? or recommendations?). I also pulled the deck off, seems to be 42inch with no guide wheels, that normal? All spindles and blades spin freely and little to no through rust, looks to be all surface (overall I'm pretty happy so far).
![]() Quote:
tires: http://cgi.ebay.com/ws/eBayISAPI.dll...=STRK:MEWAX:IT
Thanks for the link, the current tire on the tractor is "Goodyear Highlander GT" 4.8-8. I'm assuming the rim is 3.75" or 4" wide.
Yeah. You definitely have the narrow rim. My preference.
Is there a how-to for mounting your own tires? Or would I have to take them to shop?
Nice looking 128!
![]() Quote:
And also look on you tube.
Your 128 is made in 1971. I can tell by there is no 3 holes on the left side of the frame.
1971 128,3pt,ags,rebuilt motor,headlights 1988 1812,dual ports 1966 122,creeper,3pt,ags,sa,headlights,restored 1st place at RPRU 2013 1966 123,3pt,brinly spring assist 1973 108 1968 125 Attachments:QA36A,wfblade,2 nf blades,brinly disc,a cultivator,plow,homemade wrecker boom with 2000lbs winch,ih weights,50lbs weights,2IH windbreakers |
Is it ok to wash the tractor if I disconnect the battery? Anything I Need to be careful of?
