Old 07-08-2011, 01:23 PM
CC1650Dave's Avatar
On the topic of those spindle bearings, I was doing more research and found that OCC's own Diz Jr. had opened one up to take a look at it in his 42" Deck Rebuild thread. I wanted to reproduce his pics here because they're awesome and add context:
Old 07-08-2011, 04:55 PM
CC1650Dave's Avatar
Default Measuring Throttle Shaft Play on K341 Carb
I'm getting ready to rebuild the carburetor, and the Kohler service manual tells me that "further disassembly to remove the throttle and choke shafts is recommended only if these parts are to be replaced."
I've read that too much "play" in your throttle shaft can cause problems, so how do I measure "play" and know how much is OK?
I've also read that "More than .010" of play is considered too much for throttle shaft wear."
OK, that's a bit more info. So I checked out the throttle shaft thusly: First, I measured the gap when pulling it outward with a feeler gage. There's about .040" of play there, but I'm sure that's not what we're measuring.
Then I wanted to measure the "wobble" of the shaft, the side-to-side play. The best way I could figure to do this was to stand the carb on its end and put a caliper between the bench and the shaft.
This way, I could hold the carb down, hold the shaft at one side of the bushing, then raise the shaft to the other side of the bushing and measure the difference:
I'm getting about .005 to .006 in play using this method. I guess it's OK, but your thoughts would be appreciated.
The choke shaft seems to be solid, almost no play at all, so I'm not going to be concerned with that one.
Old 07-08-2011, 06:42 PM
Pretty much any side to side movement or wobble is bad.
Here my link on part numbers and replacement screw size for the throttle plate:
http://www.onlycubcadets.net/forum/s...ad.php?t=10329
To remove the plate screws file off the back side of the screws first as they have been staked. This should allow them to come out without breaking.
Old 07-08-2011, 08:00 PM
CC1650Dave's Avatar
Yeah, I see that it's only a couple bucks for the bushing, and you use your old shaft, so not too big of a deal to do that job. I was thinking it was going to be a $40 thing earlier.
Old 07-08-2011, 08:07 PM
It can be if you want to pay that, LOL. I found the bushings at ACE Hardware. The shaft itself doesn't wear, it is the aluminum housing of the Carb body that wears and allows the shaft to move around and creates a vacuum loss that can make the carb surge and not adjust properly. Those bushings will tightening it up perfectly for another 20 or 30 years, then pop them out and put two more in and good to go again.
Old 07-08-2011, 08:17 PM
CC1650Dave's Avatar
Re-reading Matt's instructions, I see that he did the same thing with the bushing, so now I'll see if my local Ace hardware has that part so I don't have to mail order it.
Old 07-09-2011, 10:35 AM
Sugarmaker's Avatar
Dave,
Nice pictures! And documentation on your restoration project for the 1650!
I think I may replace the bushing in the carb on the 127. It doesn't idle worth crap. Is there a part number at Ace? or do you have the size of the bushing?
Regards,
Chris
Casbohm Maple and Honey
www.mapleandhoney.com
Old 07-09-2011, 11:27 AM
CC1650Dave's Avatar
DX3 had all that in his post:
The Servalite part number is: ST814-2
They were about .80/each
Size is 7/16"x1/4"x1/16"
Old 07-09-2011, 11:38 AM
CC1650Dave's Avatar
And Sugarmaker, you're likely not "replacing" a bushing, but adding two of them. There was no bushing there from the factory. Matt G. has some instruction here.
Old 07-10-2011, 08:09 PM
jsoluna's Avatar
jsoluna jsoluna is offline
Great writeup! Very thorough....
In regards to throttle shaft bushings - when I first got my 129 in April, i could barely get it to stay running even after a good cleanin and tuning. Every bit of throttle control from linkages to throttle shaft rattled like a you know what.
I've always been impatient, so I scoured the house looking for a bushing to get the Cub ready to run. Found one of those small washers that fit in a household faucet. Drilled out center hole and trimmed the edges, lubed the I.D. to allow throttle shaft to move freely. Worked perfectly for the last few months, the engine idled perfectly afterwards and lost it's high RPM misfiring.
I actually giggled after seeing that my rigged up bushing worked
Took carb off the other day to adjust valves and remembered that I had picked up a bronze bushing at Tractor Supply in the hardware section. Had to grind the "hat" of the bushing off to get it to mount flush with the carb body, but other than that it was a perfect fit.
