Looking at a Cub Cadet 682 that's for sale.
The ad says "The Kohler engine turns over and runs, however it fouls the points with oil after a short time." Would this just be a seal? Or is it a bigger problem than that? ![]()
-105___ Tiller |
Worn push rod. Cheap and easy fix.
Tyler Chiliak. Southeast Alberta Canada. My dad and I own, 1650, , 1450, 1250, 1250, 1200, 982, 782, 149, 149, 149, 128, 128, 123, 100, 100. Also a 1310, 1500, and 2 1600 IHC trucks. |
Thanks Tyler!
-105___ Tiller |
Also wondering if KT-17 motors have any problems, weaknesses, etc?
-105___ Tiller |
Also, whats the best way to tell if the motor is a series I or II?
-105___ Tiller |
The series 1 motors are prone to blow up if they are ran at steep angles. The rod journals are lubricated by oil falling off the cam and when you get it at a steep angle, it misses the rod that is higher in the air. The series 2 motors fixed this problem by increasing the oil pressure and lubricating the rod journals directly through the crank.
The only problem I consistently hear about with the series 2's is the crankcase filling with gas. It usually caused by either a bad fuel pump or the carb needing rebuilt. As far as telling the difference between the 2 engines, I don't know of a way to do it accurately with out tearing into the engine. There are a couple of things that can make you lean one way or the other. The series 1 engine had a pipe plug for the oil fill. Series 2 engines had a plastic oil fill tube, but I've seen series 1's where the plastic tube was added. Also, the later series 2's have provisions for a external oil filter, but early ones didn't. The series 2 engine I have is out of a 1985 682 and it doesn't have oil filter provisions. Maybe the 1710 and 1711 engines did. Lastly, all series 1 engines have the better carter adjustable carb. But some series 2's have them also. The only way I know of to truly tell if you have a series 1 or a series 2, is to pull the cover plate off and see if it has a oil pressure check relief valve. That was one of the improvements of the series 2.
1980 [COLOR="Red"][/COLOR]482- Stock 1981 [COLOR="Red"][/COLOR]582- Mag18, Sleeve Hitch, Spring assist 1979 [COLOR="Red"][/COLOR]682- Mag18, Sleeve Hitch, Spring Assist, #1 Tiller 1980 [COLOR="Red"][/COLOR]782- Mag18, Sleeve Hitch 1983 [COLOR="Red"][/COLOR]982- Stock, Fully Optioned |
![]() Quote:
If the spec number is 24299 or lower, it is a Series I. Numbers 24300 and higher indicate a Series II. Check out this link for engine manual: http://onlycubcadets.net/forum/showthread.php?t=4649 |
