Old 05-21-2011, 11:16 AM
jpianalto jpianalto is offline
Default pto fiber wear button
any tricks to installing the pto fiber wear button? it's very tight and i'm afraid i'm going to break it...
thanks,
j
Old 05-21-2011, 11:24 AM
never mind! i just broke it... i wasn't tapping hard on it either.... i'm so upset! i finally got the dang thing and within 5 minutes broke it! ugh! if i had seen the brass ones before, i would have ordered one!
Old 05-21-2011, 01:32 PM
TEET's Avatar
TEET TEET is offline
Ugh..thats no fun! I replace mine with the bronze ones, and those are a tight fit as well. I usually end up filing down the shaft a bit to make it go in without too much hammering, yet snug enough to not fall out.
Jeff (teet)
CCC 1211
71
127
102
122
1962 Original
Old 05-21-2011, 04:16 PM
booger booger is offline
Broke the new one I had also,
A little dab of jb weld holds it now, been 5-6 years.......
Old 05-21-2011, 04:34 PM
I always filed down the shaft for a decent fit and used black RVT to hold them in. Never had a failure.
Old 05-21-2011, 05:24 PM
anyone had any trouble with the brass ones? i just ordered one :-/
Old 05-21-2011, 06:43 PM
108cubber 108cubber is offline
Where did you order it from? My fiber only lasted two minutes.
Old 05-21-2011, 07:00 PM
i ordered it from chris... good button but i didn't install properly what about brass ones? i found one on ebay...
Old 05-22-2011, 02:02 PM
cubdrummer cubdrummer is offline
I file it down and use a pair of channel locks with a small piece of scrap metal that i put on the pto side,and press it in.You will need to file the brass ones to get a good fit.
Old 05-22-2011, 08:27 PM
When I put the fiber ones on I clean out the hole on the PTO arm with some 150 sandpaper.Then I taper the fiber button with the same 150 grit paper.Using the turnbuckle on the PTO rod,I slowly turn it until it is seated in the hole on the PTO arm.Then I tap lightly with a hammer to set it tight .Most times I get two buttons just in case the first one breaks,but I have had no problems since doing it this way.
Up to 530 and counting...
