Hey Nate
I would use a gun and be sure to spend the extra $$ to add the catalyst (hardener) to it. If you don't have a gun and want a cheap one that will do the job and give you a chance to hone your painting skills without worrying about messing the gun up get an HVLP gravity feed one from Harbor Freight for around $15-$20. Although I have DeVilbiss and Sharp paint guns I purchased a cheap $20 from HF to spray primers with and found that it did a real nice job spraying my paint. I'm not a big fan of buying junk when it comes to tools but this time it paid off. Good luck, take your time, and make sure you have fun doing it. |
Here's a picture of my 4 digit Original rear section. I painted the whole tractor using one of my "cheap" spray guns. Don't mind the over-spray tires, I use them to move my restoration projects around while working on them.
There is the IH Harvester data plate on the left side next to the brake pedal. It reads Serial: 2050670U563551 . Im not sure where thats at with the paint color guide.
Here's the link for the paint chart and codes:
http://www.onlycubcadets.net/forum/showthread.php?t=19
IT'S A LAWN TRACTOR ! just clean it and get the loose rust off and foam roller or brush paint it if you do not like the way it looks wait untill it hardens this summer and wet sand out the runs or whatever an spray can clear coat it
![]() Quote:
![]() ![]() Its a graden tractor! The big box stores sell lawn mowers! Nathan stay the course and you'll be fine. ![]() |
Well said, Duke!
![]() Quote:
