Thanks for all the compliments. The colors are IH red and white from TSC. Just a rattle can paint job. I have always liked the looks of the Cubs that are painted red and white, just something different. Mike
#410 was the only Red Original that the Divisional Product Committee got to lay eyes on in Oct.13,1960...Oct.29 they ruled to go with Federal Yellow. Pic taken at the Red Power Roundup last year in LaPorte,IN.
Fool me once shame on you,fool me twice...shame on me! |
Well, a couple of days after I took the pictures, I took the tractor out and used it. It probably worked more that day than it had in 15 years and it became apparant that some other items needed attention. I knew I had a problem with the right rear axle bushing and pulling the axle confirmed that. Also discovered that the brake didn't work and found out that that was most likely due to overfilling the trans with lube. Both axle housings had oil and sludge in them. After cleaning everything up and ordering some parts , this is where it currently sits. Mike
Sorry you had issues with you axle! Did you find a replacement for it? Tractor is looking good, keep it up!
Jeff Brookfield, MO ________________ IH Red 782 with weights and sleeve hitch! IH snow blade, Brinly plow, Brinly disk, Brinly harrow, Johnson rear blade, and a #2 IH Cart |
Looks like that axel is toast!!
Yes, I have an axle coming, along with new bushings. That old axle is pretty much gone. I had an old riding mower when I was a kid that I used to mow neighborhood yards and the axle broke on it while I was mowing. The mower had a plastic bushing that had worn completely through but was good on the other side. My Dad worked with some professional welders at the time and one of them welded the axle back together and my Dad ground the weld down smooth and you couldn't tell it had broken. I flipped the bushing over and went back to mowing and sold that mower about ten years later still working. I might see if someone could weld material back on this axle and then turn it down on a lathe, what's to lose. I really like this old tractor. Mike
