Old 03-25-2011, 12:21 PM
GoatDriver's Avatar
GoatDriver GoatDriver is offline
Default The 86 is running again!!
After I got my 86 running and then had to rework the driveline in it...everything was just fine and then the intake lifter/tappet stuck in it.... I tried to get it unstuck for awhile with no luck...another project came up...I had to refinish some antique furniture for my granddaughter that is due in May...so the 86 got pushed around behind the shop with the intent of a rebuild..
Yesterday, I rolled her back into the shop and pulled the head, valve cover, and intake valve and worked the lifter up and down while spraying with carb cleaner and then some PB Blaster...after about 30 minutes of this it broke loose and is working fine now. I cleaned the block and head up, changed the oil, lapped the valves and reinstalled them...put the old head gasket back on just so I could crank it up and it worked fine (only ran it for a minute). Still has the standard piston and very little wear in the cylinder. Ordered a new gasket set for it, should be here by Wed. of next week. Taking the head to have it trued up today. Just giving an update on another old Cub...she's still clicking along!! Thank ya Lord!
Cub Cadet 126 - Cub Cadet 86 - Cub Cadet 108
The majority as to numbers, wealth,and political influence are often wrong. If in such cases a person would do right, he must not be governed by public opinion, however it may be expressed, but by the law of God. {see Proverbs 4:14}
Old 03-25-2011, 01:20 PM
Glad you got the 86 going again!
Old 03-25-2011, 08:25 PM
GoatDriver's Avatar
Here's a pic of my 86 in my yard today
Old 03-25-2011, 08:35 PM
JaysNJcub127's Avatar
JaysNJcub127 JaysNJcub127 is offline
Default hmmmm
a little topaz adjust?
1969 Cub Cadet 127
Cub Cadet HDS 2155 w/ bagger
#2 IH cart
48" deck
42" Front Blade
Brinly Sleeve Hitch and Brinly Plow
IH wheel weights
Old 03-25-2011, 08:41 PM
GoatDriver's Avatar
Ah..a fellow Photoshopper...huh?
yeah, a little TA and a few other adjustments on a couple of layers....
Old 03-25-2011, 09:08 PM
And the watermark is a nice touch too! I'm glad you got the 86 running again.
Old 03-25-2011, 09:42 PM
GoatDriver's Avatar
Thanks! I made the water mark with a transparent background, I then copy it and paste it into a new layer and adjust the opacity of that layer for the way I want it to look. The "Deep Woods" derives from my business name.
Old 03-25-2011, 10:09 PM
That's awesome, cool pic!
