Old 06-19-2009, 11:25 PM
wig wig is offline
Default Rear end swap question
Will a rear end from a 129 hydro be a direct replacement for a 782 rear end? The reason I ask is my 782 has internal brakes and I can buy a 129 hydro rear end with external disk brake for cheap. Would also have the complete 129 minus rear end for sale cheap if it would work.
Old 06-19-2009, 11:29 PM
murphycc
Guest
Posts: n/a
Yes you can, I'm doing the very same thing with a 1450 iron rear that I'm replacing in a 1811/782/????
My current project is a 582 iron gear drive in a 1811 frame with external brakes. I'm ignoring the internal.
You'll just need the correct linkage to the brakes.
Scott
Old 06-20-2009, 06:33 AM
wig-
Just remember you'll have to swap pumps, as the 129 pump isn't ported for the hydraulic lift.
