Old 06-18-2009, 02:00 AM
GERKS 149 GERKS 149 is offline
Default taking apart a spindle
I have a 68-71, 42 inch deck - square ends. Can anyone tell me how to get the spindle apart the right way? First, I took the screw in zerk fitting off and then took the pulley off and tried to slide the spindle out the bottom. Well, I ran into a tight fit as it was going through the bearing. Should I use a little force, or do something different? The spindle # is: 489391-R1. I think these have a tapered roller bearing inside. They are a little loose and I would like to rebuild them.
Thanks for your input,
Mark
Old 06-18-2009, 07:45 AM
Mark:
Click on this link...... Manual
Go to the reference link and look at pages 3-4 thru 3-6.
Old 06-18-2009, 02:48 PM
jkier's Avatar
jkier jkier is offline
http://www.onlycubcadets.net/forum/showthread.php?t=839
I just rebuilt mine, I took a couple of exploded view pics in that thread
Had to use a little heat to get them apart
Then froze the races and heated the spindle to get the bearings back in
Old 06-19-2009, 02:07 AM
Thank you for the diagrams. This will be a big help to me since I am a novice to these tractors. I guess it needs a little force or help to get it apart!!
Thanks,
Mark
