Old 09-07-2026, 09:45 PM
Cubcadet782desiel Cubcadet782desiel is offline
Exclamation cub original clutch
on my original whenever you let the clutch out in any gears it will squeal it wont do it if you slowly ride the clutch when letting it out.When I was plowing with it in first and I would hit a hard spot instead of spinning the tires it would slip the clutch the drive belt is not slipping. I had 2 IH wheel weights on when plowing so not like it couldn't spin the tires if the clutch was working correctly. thanks,
Original,782,782d
Old 09-08-2026, 09:39 AM
I do not know the condition of the clutch new parts? otherwise adjust the clutch if it is slipping. As for the belt it should be a 3/8" wide belt.
Up to 534 and counting...
Old 09-09-2026, 07:08 PM
how do you adjust the spring?
Old 09-09-2026, 07:35 PM
In the technical library there is a chassis service manual for the original.
Check it out.
