Old 06-24-2010, 11:05 PM
Default Interchanging Decks?
I am wondering if I can interchange a quick attach deck with a pin on deck. I have a 149 with a 42" quick attach deck and I also have a 123 with a 48" pin on deck. I was wondering if I could put the pin on deck on the 149 with very little re-working. Normally, I would look at them and compare them myself, but my cubs are over 35 miles apart right now and I will not be at my other place for several more days. I don't know whether I should drag my 149 along or not and about how much time I am looking at to convert hardware. Thanks in advance for considering my question.
Old 06-24-2010, 11:23 PM
Put the pin-on subframe on the 149's mule drive. I think that'll work. I know you can mix and match NF QA and pin-on stuff. All bets are off for the belt though...neither one may fit, or one might. You'll have to experiment with that.
Old 06-26-2010, 05:44 AM
bigdaddyjak bigdaddyjak is offline
I have put both on the same machine they work fine ! Also I have not bought a belt, they were on them when I got them although I have taken them all off (decks and belts) and just put them back on at random, they work fine for me ! Just as long as u use the proper sub frame as MATT stated, or switch hardeware around if U choose, Will work fine also !
To much to list!
Old 06-27-2010, 10:50 AM
Thanks fellas!! The advice and expertise is greatly appreciated.
Old 08-21-2026, 03:17 PM
EternalArianne EternalArianne is offline
I hate to resurrect this old thread (I found this thread while googling), but I'm in a similar boat where I have the pin-on undercarriage on my 102 and a guy near me has a 38in QA deck. Is it as simple as replacing the QA mounts on the deck with the pin-on style? I imagine you could use the QA mounts on the rear but would need to replace the front mounts with the eyelet hooks for the pin-on style? Or is there more to change out?
Old 08-22-2026, 10:01 AM
The mounting holes for the pin on the rear brackets are not the same as the QA ones.Do you have QA laying around?
Up to 534 and counting...
Old 08-22-2026, 07:26 PM
I don't have a QA frame but if the holes just need to be bigger I can "waller them out" on a drill press.
Old 08-22-2026, 08:29 PM
You will still have an issue with the front ones. They will not work on a QA deck. You can try the eye bolts, but I think that they will have to be modified.
Old 08-22-2026, 10:47 PM
I looked at the parts diagrams for both the deck and the undercarriage and the deck seems to be the same regardless of if it's QA or pin-on; the mounting hardware is what varies with the undercarriages. So hopefully it will all work just fine. I'll find out in a few weeks when I can go get the deck!
