Old 07-27-2026, 11:09 AM
MiniXP MiniXP is offline
Did you replace the pins with Spirol pins and NOT split pins??
Yes, I had a spare roll-pin from the last time I did this year ago, just replaced the rear one.
The front one is actually a solid pin, not sure why that one is solid and the rear one is a roll-pin, I believe they are both the proper part numbers though.
I did debate swapping the front one out for a roll-pin, would make sense for that one to be the weak point since it doesn't require splitting the tractor to replace. I'd be interested if anyone has a roll-pin at the engine side of the driveshaft as well, as I still may do that in the future.
Old 07-27-2026, 11:21 AM
Yes, the front coupler pin is a hardened pin.
The rears should be HD Spirol pins and not split roll pins.
You will probably be working on this again next year if you use it on a regular basis.
Old 07-29-2026, 02:04 PM
About 8 years ago when I first started using this for routine mowing, I did go through a couple of spirol pins and roll pins, among other issues. Think I just had some kinks to work out since it had been probably 20-30 years since it saw routine use.
The past 3 or 4 years though have been pretty good, not too many issues up until now. I did replace both the front and rear couplers on the driveshaft and the rag joint, so that may have helped take some slack out that may have been wearing on the pins.
Overall though, splitting the tractor was easier and quicker than I remembered. You can tell these were built to be serviced and repaired, rather than disposable like most modern stuff.
