Old 07-17-2026, 11:14 AM
BobbbS BobbbS is offline
Default Load (Clutch) Spring for CC108
I think I might have the wrong clutch spring that came form Amazon. Description says it for a 108 as well as others. When I compressed it with all other parts installed on the drive shaft it looks like it's compressed so much that there is very little spring left to compress when applying the clutch pedal.
New spring not installed is 6 5/8 in. (uncompressed)
Old spring not installed is 5 5/8 in. (uncompressed)
I'm tempted to put the old spring back in.
Thanks for any input.
Old 07-17-2026, 12:12 PM
6.5/8 is the correct length. Do you have all the parts installed in the correct order? Pix would help...
Up to 534 and counting...
Old 07-17-2026, 03:44 PM
Old 07-17-2026, 03:47 PM
I was going to take a picture of it fully assembled but could not collapse the spring enough to line up the hole for the roll pin.
Old 07-17-2026, 04:11 PM
For whats it's worth....
The new throwout bearing is slightly larger. Amazon part numbers--941-3056,
741-3056, IH-39-1237, IH-ST435
Old 07-17-2026, 05:28 PM
Both of those bearings are not oem. It should look like this one.
Old 07-17-2026, 06:03 PM
Do you have a source?
Old 07-17-2026, 07:59 PM
eBay sells them.
https://www.ebay.com/itm/336406296844
Old 07-18-2026, 07:21 AM
ironman's Avatar
ironman ironman is offline
The one on the left (old one) looks like it was machined or ground down to make it make it narrower.
Old 07-18-2026, 07:27 AM
Slightly??!!
Looks like quite a bit from where I sit!!
