I had a small coolant leak around this fitting so I had to pull the engine out again to repair it. I cleaned it up, painted it and installed new clamps. Hopefully that will solve the issue.
IMG_2439.jpeg I ordered 25' of 3/8 brake tubing off of Scamazon for $20 and also some 3/8 JIC tube nuts & tube sleeves from DiscountHydraulicHose.com. I watched a few YouTube Vids on tube bending and made these up. These aren't perfect but I think they'll work good enough for a plow tractor. IMG_2434.jpeg IMG_2438.jpeg I then got the engine put back in, wired up and installed the clicky starter relay only to find out my 15 year old China gear reduction starter has failed. It shorted out and burned up my new relay. So I ordered a new China GR starter and hope to get it installed soon.
Why Farm Half When You Can Farmall? 1282 | 44C Deck, 42" Blade, 020" Over K301 * 1711 | 50C Deck, #1 Rototiller w/ Extensions, Sleeve Hitch, CH18S * 1811 | 46 GT Deck, 42" Blade, M18, Sleeve Hitch * 1782 | 60" #375 Deck, Kubota D640 Diesel * 1862 | #450 Snowblower, M18 Magnum * 782 | Y/W KT17 Series II, Sleeve Hitch * 984 | Y/W Onan/Linamar 20HP, Sims Cab, CAT 0 3 PT w/ Rear PTO, 60" #374 Deck * 1914 | 44C Deck, KT17 Series II * 127 * 1650 Twin Stick | 50C Deck, 42QA Snow Thrower, K341 * 1862 |
I plowed the garden a few weeks ago and so far it's working great. This was some pretty hard plowing because I let this garden get ahead of me with lots of weeds and grass.
Good work Todd.
Yeah, those lines don't stand a chance, against a flopping driveshaft. ![]() I remember well, when my Super, let go...
I bet you do. it is good to see you back.
1572, 1864 x2, 1810 x2, 1863 & GT1554(Dad's Ole Mowers), 1811,782D, 1872 x2, 782DT(Sold), 3235, 1860, 1772 with 3-point and Turbo. |
Good to hear from you Zippy!
I gotta give you a shout for a good BS session.
Perhaps it might be wise to fabricate some guards so that the next time a drive shaft goes to pieces, the spinning remnants will be less likely to produce as much collateral damage?
A pair of 100's, both look fairly well stock, one with a creeper, and a snow plow that will never see snow here in south Florida, and now a 122 with a deck |
Jay 40 years of Using and playing with IH Cub Cadets! Proud owner of the following: Cub Farmall, Super A Farmall, Original, (2)70's, 72, 100, 102, 123, 105, 125, 127, 108, 128, 1450, (3)782's, Yellow 982, 1782, "Sam's" 2182, M Farmall and a #7 trailer |
