Old 02-27-2026, 04:46 AM
I had a small coolant leak around this fitting so I had to pull the engine out again to repair it. I cleaned it up, painted it and installed new clamps. Hopefully that will solve the issue.
I ordered 25' of 3/8 brake tubing off of Scamazon for $20 and also some 3/8 JIC tube nuts & tube sleeves from DiscountHydraulicHose.com. I watched a few YouTube Vids on tube bending and made these up. These aren't perfect but I think they'll work good enough for a plow tractor.
I then got the engine put back in, wired up and installed the clicky starter relay only to find out my 15 year old China gear reduction starter has failed. It shorted out and burned up my new relay. So I ordered a new China GR starter and hope to get it installed soon.
Old 02-28-2026, 01:50 PM
Farmall450's Avatar
Attachment 117815
Attachment 117813 Attachment 117814
I see a common problem with the starters (China)
Old 06-22-2026, 04:53 AM
I plowed the garden a few weeks ago and so far it's working great. This was some pretty hard plowing because I let this garden get ahead of me with lots of weeds and grass.
Old 06-30-2026, 04:37 PM
Good work Todd.
Yeah, those lines don't stand a chance, against a flopping driveshaft.
I remember well, when my Super, let go...
Old 06-30-2026, 05:13 PM
CubDieselFan's Avatar
Good work Todd.
I bet you do. it is good to see you back.
Old 07-01-2026, 04:18 AM
Good to hear from you Zippy! I gotta give you a shout for a good BS session.
