Old 06-18-2026, 10:52 PM
britishham britishham is offline
Default Trying a cut friday 6/18
Back to a working lawn mower.
Have asked various dealers even Tuff torq for an answer to
What is the differance between a 7a632084830 and a 7a632084840
Tuff torq say made for differant tractor company
But Google ai say both where used on a gx54d
Any expert know, the pictures of both boxes look identical to me.
THANKS COLIN
Old 06-19-2026, 05:44 PM
Default hydrostatic model
Any tech know differance between kt62af and kt62ag Tuff torq just informed made for differant mower group
Are they interchangable on a gx54d
THANKS
Old 06-19-2026, 08:47 PM
Billy-O's Avatar
Billy-O Billy-O is offline
THANKS
This is what comes up on Google search with AI answering:
The Tuff Torq KT62AF and KT62AG are specific, manufacturer-configured variants of the Tuff Torq K62 hydrostatic transaxle series.Because both share the baseline K62 architecture, they have identical core power ratings: a 10cc pump and motor displacement, a maximum input speed of 3,000 RPM, and 1-inch (25.4mm) heavy steel axles.The primary differences between the KT62AF and KT62AG focus on internal gear reductions, control setups, and vehicle-specific mounting hardware configured for different tractor brands.Key DifferencesInternal Gear Ratios: Tuff Torq assigns the final two letters of the code (like "AF" vs "AG") to signify a unique internal build combination. The K62 platform utilizes two primary reduction ratios: 26.90:1 (optimized for high torque and larger 23-inch tires) and 18.65:1 (optimized for higher ground speed with smaller 18-inch tires). One variant is geared for higher torque/larger tires, while the other is geared for smaller-tired yard tractors.Control Lever & Linkage Configurations: The mechanical control arms that connect to the tractor's forward/reverse foot pedals or cruise control linkages are clocked differently. Tuff Torq customizes the angle, throw length, and spring-return stiffness of these arms depending on the specific ergonomics of the mower brand it is built for.OEM Part Number Target: These sub-models are mapped to different original equipment manufacturer (OEM) part numbers (such as MTD, Cub Cadet, Simplicity, or John Deere numbers) to ensure direct bolt-in capability for a specific tractor chassis.Core Technical Specifications Shared by BothFeatureSpecificationAxle Diameter1.0 inch (25.4 mm)Pump / Motor Size10 cc / 10 ccMax Input Speed3,000 RPMBrake TypeInternal Wet DiscHousing CaseDie-Cast AluminumFluid CapacityApprox. 2.5 Liters (Recommended: 5W-50 Synthetic)Identifying Your Exact UnitBecause these letters denote specific production builds, swapping an "AF" directly for an "AG" without modifications can result in backward pedal operation, incorrect travel speeds, or mismatched brake linkages.To determine the exact swap compatibility, check the barcode label on your transaxle case. You can verify component cross-compatibility or buy exact-fit replacement kits directly from the Tuff Torq Official Parts Store.Are you planning to replace one of these transaxles with the other, or are you currently sourcing internal repair parts? Tell me your tractor's make and model so I can confirm exact fitment.
Plow blade
#2 Cart
QA36 snowthower
Old 06-22-2026, 09:33 PM
Default Changing transmission on gx54d
HI
I was searching for replacing the kt62af/ 830 for a kt62ag/ 840 looks identical 840 is cheaper but it seems as you state gear ratio internal could be differant
Would the 840 work in the gx54d
THANKS COLIN
Tags
hydrostatic, transmission, tuff torq
