So far, I think it’s fixed!
Unfortunately I can pin point which failed since I replaced a few things but I believe I had more than one issue. Replaced points and adjusted to 0.20”. Mounted the condenser to the engine block. Replaced the coil with a new kohler brand. Start right up and ran around the yard to warm it up and adjusted carb. So far it still starts and runs great. Throttles up no problem. Hopefully it’s good to go now. Just ordered a box blade for it. Does anyone have a good write up on removing the mower deck? |
An improperly mounted condensor may have caused your throttle up issue. You can run without it but you would have erratic issues and cook your points..... whatever it was, glad it's all good for you!
Two 125's and a 124 all with 42" decks Plow blade #2 Cart QA36 snowthower |
I read the coils needed mounted to a good ground. The coil was mounted on the shield under the fuel tank. Which certainly does not have a good ground to begin with. The condenser was mounted to the coil bracket. Found a bolt close by in the block and used that. |
Still seems to be all good. Been starting it and driving it around the yard every day after work. Thanks everyone for the help! Found the manual for the deck. Can’t read the serial tag but it measures to be a QA 44. Going to pull that off this weekend and overhaul it. I ordered a box blade for the sleeve hitch and it will be here this coming week. Plan on grading the driveway next weekend with it!
