Old 05-16-2026, 08:13 PM
SDBOB SDBOB is offline
Default 1650 gas tank can the rubber ring be replaced with metal
Can the rubber ring be replaced with a metal valve of some sort? I was thinking a metal tube threaded on outside and inside. That has a flange on one end with gasket that would go into tank then outside threaded with gasket on outside,then nut clamping tightly to tank. Then internal thread for valve. I replaced rubber grommet, stopped leaking. Then yesterday tank was empty. No noticeable gas around. I was thinking leaked out over a week a dried up.
