Hi All,
I have a 1527 that I have owned since it was new. I think the hydraulic drive is bad. It's been burning drive belts within minutes of me putting them on. The last one I put on, I pulled the fenders off and got to looking at the hydro. It spun just fine but seemed stiff. I don't know what a good unit would feel like so I put it back together and installed the new belt. After about 3 minutes it started smoking. I really don't want to get rid of the tractor. It only has 400ish hours and the Kawaski motor is great. So I would like to fix it but I have other mowers and don't think it's wise to put a lot of money into this tractor. I see other Cub Cadets that look like they are very close to my 1527, I wonder if the hydro unit can be swapped? Does anyone have any tips? Thanks
1952 Farmall Cub 1972 Cub Cadet 129 1975 Cub Cadet 1250 2005 Cub Cadet 1527 1978 Cub Cadet 1650 1979 International 184 Low boy |
Here is the service Manual https://www.hydro-gear.com/wp-conten...N-51260_P8.pdf
0riginal, 60 RER, 70, 106, 1450, 1541, 2182, 3208, XT3GSX & SX54 Z Force |
If and when you do a service use a full synthetic oil for a longer change-over period and in my opinion works better
Hydro-gear recommend either a regular oil or synthetic Oz
My wife says I do not listen , at least I think thats what she said |
Ok, it's been a long time but I have had many projects and this one got put on the side. Today I looked at the tractor again and started it up, the smoke is coming from directly under the engine. i don't know if this means anything, but I am not convinced my problem is the transmission. Anyone have any thoughts?
You have three idler pulleys involved in that drive belt system. You haven't mentioned you have inspected them and that they spin freely.
Did this problem arise and cause you to change the original belt or did it arise after you changed the original belt. Have you double checked to see that you have the drive belt routed correctly? If something is binding so that the belt cannot move, of course smoke will be produced from under the engine because that is where the drive pulley is and the belt is spinning in the drive pulley. |
Good information, it arose after I changed my original drive belt. I haven't checked all pullies, that is something I will need to do. Thank you for your reply. I'm not sure when I'll get to it but I will reply when I do.
