I had a small coolant leak around this fitting so I had to pull the engine out again to repair it. I cleaned it up, painted it and installed new clamps. Hopefully that will solve the issue.
IMG_2439.jpeg I ordered 25' of 3/8 brake tubing off of Scamazon for $20 and also some 3/8 JIC tube nuts & tube sleeves from DiscountHydraulicHose.com. I watched a few YouTube Vids on tube bending and made these up. These aren't perfect but I think they'll work good enough for a plow tractor. IMG_2434.jpeg IMG_2438.jpeg I then got the engine put back in, wired up and installed the clicky starter relay only to find out my 15 year old China gear reduction starter has failed. It shorted out and burned up my new relay. So I ordered a new China GR starter and hope to get it installed soon.
Why Farm Half When You Can Farmall? 1282 | 44C Deck, 42" Blade, 020" Over K301 * 1711 | 50C Deck, #1 Rototiller w/ Extensions, Sleeve Hitch, CH18S * 1811 | 46 GT Deck, 42" Blade, M18, Sleeve Hitch * 1782 | 60" #375 Deck, Kubota D640 Diesel * 1862 | #450 Snowblower, M18 Magnum * 782 | Y/W KT17 Series II, Sleeve Hitch * 984 | Y/W Onan/Linamar 20HP, Sims Cab, CAT 0 3 PT w/ Rear PTO, 60" #374 Deck * 1914 | 44C Deck, KT17 Series II * 127 * 1650 Twin Stick | 50C Deck, 42QA Snow Thrower, K341 * 1862 |
