Old 01-30-2026, 03:09 PM
SDBOB SDBOB is offline
Default 190 -450-100 snow blower speed explanation
I'm looking to get a snow blower for my 2082. Local CC dealer is saying there are 2 blowers one spins slower than the other. He is saying you want the faster blower. I have an ad in wanted section for the 450. Which one is better? I'm new to these blowers. Thanks. Bob
Old 01-30-2026, 03:41 PM
There is a good write up about those blowers here https://www.cubcadetcollectors.com/f...pic.php?t=6684
Up to 534 and counting...
Old 01-30-2026, 04:03 PM
Depends on the serial number of your machine
SN 800,000 - 821,059 450 blower
SN 821,060 - 836,000 451 blower
Old 01-30-2026, 04:50 PM
Mine is 820826. I received 'all' the paper work with tractor. According to cub cadet accessories booklet I got, it takes the 450. Sooo .We got hit with snow my friend got about 12-16 inches. We got 6-8-12. Luckily its dry not wet. Havent seen or shoveled this much in 20 yrs,if I 'remember'. Thanks guys again.
Old 01-31-2026, 11:10 PM
Member here contacted me. He is close to me. I just want to be prepared for any maintenance this blower may need before I use it. Can anyone with experience give me some, or what to look for when I look at blower. I'm just being prepared.
Old 02-01-2026, 09:36 AM
Frank1541 Frank1541 is offline
These things are pretty robust. My 450 (with a 451 gear box) is 40 years old and has been used every winter. Main thing to look at are the gear boxes. Make sure they have the right lubricant in the right amount.
If you can, pull the auger off the gear shaft and inspect the splines. Sometimes the splines fail due to corrosion. I always put never seize on the splines. Also make sure the bearings in the pulleys are OK.
2364i (1541)
Kohler ECH23
Power Steering
54" Deck
451 Snow Blower
42" Plow
Old 02-01-2026, 10:54 AM
Thank you. That's the kind of info I need.
