Old 11-16-2025, 11:29 PM
ARCubfan's Avatar
ARCubfan ARCubfan is offline
Default 1250 that kept losing power
All, hopefully I'm not jinxing myself here but I wanted to share in case someone else has this issue.
My 1250 would lose power when running under load after about 15 minutes. It would bog down so low that if I didn't throttle down it would die.
I tried just about everything troubleshooting this issue including, checking the head, replacing the voltage regulator, coil, adjusting the governor, and the points. Nothing worked.
One thing that I noticed from the day I bought the tractor was the voltmeter always showed that it was charging a lot. I don't have a good analog meter so I couldn't get a read on what was being fed to the battery. Well the starter went out on the tractor so I replaced it with one I bought off of Amazon.
First thing I noticed was how much quieter it is when starting the tractor. Second, the voltmeter is now looking normal and it not once has bogged down after it's been warmed up.
I can't explain it, but I think the starter was causing all my problems. Hopefully, this might help someone some day.
1952 Farmall Cub
1972 Cub Cadet 129
1975 Cub Cadet 1250
2005 Cub Cadet 1527
Old 11-17-2025, 11:02 AM
CubDieselFan's Avatar
Yes, hard to explain. My best guess is that you had a bad connection somewhere and you fixed it when you changed your starter.
Old 11-17-2025, 08:41 PM
ARCubfan's Avatar
Yeah, hopefully that was the fix and I'm good. So far I have run it for at least a few hours and it's been perfect.
1952 Farmall Cub
1972 Cub Cadet 129
1975 Cub Cadet 1250
2005 Cub Cadet 1527
Old 11-17-2025, 08:50 PM
Billy-O's Avatar
Billy-O Billy-O is offline
It seems to me that maybe the old starter was causing problems where as it could have caused the solenoid to stick this giving you funky voltage or amp readings on your gauge and. If I were you, I would maybe consider replacing the starter solenoid to be on the safe side.
Plow blade
#2 Cart
QA36 snowthower
