Old 10-21-2025, 12:35 PM
Merkman Merkman is offline
Default PTO acting wonky
2544 GT My PTO starting to act weird. It was engaged upon startup and would not disengage unless I lifted off the seat. When disengaged It would engage but not disengage! I cleaned the switch connection and cleaned the fuses
Any experience such behavior? Any ideas
Thanks
Old 10-21-2025, 01:28 PM
ironman's Avatar
ironman ironman is offline
Please explain what you mean by "It was engaged upon startup".
Does that mean it was already engaged when you started the tractor, or it engaged itself when you started the tractor, or you engaged it after you started the tractor?
Old 10-21-2025, 02:37 PM
Tractor started and blade was engaged with switch in.
Old 10-21-2025, 03:25 PM
You either have a wiring issue or bearings starting to fail in your PTO. Probably a wiring issue the way you explain it. Do you have a meter and know how to use it? Here is a wiring diagram of the 2544's but I'm not sure which year yours is.
https://www.ccpartsnmore.com/cub-cad...ing-schematics
Old 10-21-2025, 03:31 PM
I do and I do, will track it down, thanks
Old 11-17-2025, 09:02 AM
When I pull the 2 wire plug off from the pto, it remains engaged. Would I be correct in thinking I have a bearing seized in the clutch?
Old 11-17-2025, 01:26 PM
You would be correct, you have a bearing that is done.
Old 11-17-2025, 03:25 PM
Thank you Sam, is that a bearing that can be replaced or the unit itself gets replaced?
