Old 07-10-2025, 01:05 PM
CVACUB CVACUB is offline
Default Generator bearings 122 cub help please
It seems every time I touch this tractor a big can of worms is opened so I got the generator starter apart and the back bearing is a caged ball bearing. I was able to remove the outer race and the cage out but now the inner race is frozen to the shaft can I apply heat to try and remove it. Also just test fitting the new sealed bearing inner race barely gets on the shaft at the end so is this a pressed on bearing which doesn’t make sense because I will not be able to have it adjust once it’s back together and the front bearing gets past the threaded end and then it stops. Am I better off spending the $$ on a rebuilt or new generator starter which I really don’t want to do
Old 07-10-2025, 01:45 PM
Graflex45's Avatar
Graflex45 Graflex45 is offline
One option- suspend it from something into a small cup of evaporust to try and clean up the shaft to remove that race.
But- that armature wire insulation looks like its flaking off. If it is I'd look for another generator for and try and rebuild it with that armature if yours is in bad shape
1450- 44A deck,QA-36 snowthrower, 42in front blade No.2 Tiller
70- 38in deck, 42 inch deck
Old 07-10-2025, 01:59 PM
Ok you just made the choice very easy
New one. Anybody tried DB Electric
Old 07-10-2025, 03:14 PM
I just bought a new starter for my 3 year old SCAG Vanguard. It fit, it works, it was fast and it was a good price.
Old 07-10-2025, 08:15 PM
Billy-O's Avatar
Billy-O Billy-O is online now
I have a 5-6 year old db electric starter. So far, good!
Plow blade
#2 Cart
QA36 snowthower
Old 07-10-2025, 10:31 PM
Just carefully slice the remains of the inner bearing race lengthways with a die grinder/cutoff wheel taking care to not nick the shaft, then it will split at the slice and will fall off.
Old 07-12-2025, 07:24 AM
Yup, I had to replace my OEM China starter with a DB Electric for half the price Scag wanted for a new China starter too. Mine was acting up from the first week I had it but it wasn't consistent enough for me to take it to the dealer and have them let it sit outside for a month until they could get to it.
Old 07-12-2025, 08:25 PM
Order DB Thursday delivery is scheduled for Monday
