Old 04-11-2025, 06:21 PM
Wdirwin Wdirwin is offline
Default Accessing points
I wanted to inspect the points on my 128. I am new to this but I think I found them but I can't get the cover off. There is a screw on the top of the cover that is easy to access but the bottom screw is blocked by the frame.
Old 04-11-2025, 07:08 PM
Billy-O's Avatar
Billy-O Billy-O is offline
Once you get the screws out, consider replacing them with allen screws. Then it will be easy peasy.
Plow blade
#2 Cart
QA36 snowthower
Old 04-11-2025, 07:28 PM
IHCubCadet147's Avatar
There should be a hole in the frame that lines up with the bottom screw that you can stick the screwdriver through.
File Type: jpg 35E862D3-6B8A-4C3E-9954-F79E80B489DF.jpg (12.5 KB, 68 views)
Old 04-12-2025, 08:45 AM
ironman's Avatar
ironman ironman is offline
Not always, but that's what drills are for.
Then, after you loosen the screw, it helps to have one of these....
Old 04-12-2025, 09:01 AM
Such a simple question and look at all I have learned. Never thought
of changing out the screws, drilling a hole, or getting new screw drivers.
My method has always been to fight it for twenty minutes. Cool.
Really liking the buy new tools idea.
Ken
Old 04-12-2025, 10:07 AM
Stuff a towel or some rags between the frame rail and the lower engine to catch the screw from disappearing into oblivion when you drop it.
