I previously posted before I was having an issue with Brakes and Neutral, After digging into the guts with a schematic I notice many parts were missing, most importantly the linkage between the pedal and cam. The PO used a bent rod and wire. I ordered parts and the install seems straight foreward, My only question is, Does the linkage needs a certain span or do I lock the pedal all the way down and adjust accordingly? If the weather holds up I plan to dive into it tomorrow. The part I am reffering to is highlighted in attached picture. Thanks
I think the service manual probably does a decent job and how to
set the brake ( which has to be done first) and then the neutral for the hydro. https://s3.us-east-2.amazonaws.com/c...ervice+Man.pdf Ken |
