Hello all, finally getting around to restoring the deck for my 147. I did search, hopefully I was thorough enough. Does anyone have a source for the oil seals (6 required)? NAPA lists one as industrial non vehicle specific, but maybe someone has found a better option under a different PN that is more easily available over the counter and cheaper?
The PN I am working from is 530484 which doesn't lead to anything on RockAuto. Thanks. Edit: Went through the NAPA checkout page and they want me to pop for $20 shipping, so $50 bills for 2 seals........ |
I ordered the 6 oil seals for my 421u1113 right from a local Cub cadet dealer that was less than a 3 minute drive away. They still sell the seals, part was IH-473428-r92 my local dealer charged me $13.99 each. One thing I’m not 100% on tho is if the 2 possible spindle styles use the same oil seals? Mine have replaceable oil seals and bearings.
Picture of the seal and the bag it came in
Ok, thanks for that info. Luckily on two of the 3 spindles the seals feel like brand new so I'm just rebuilding one. Also glad this deck has the relatively cheap automotive type bearings/races.
My local napa dealer, free shipping !
This item is not vehicle specific. Oil Seal - Industrial Part #: NOS 530484 Line: NAPA Oil Seals Price $9.33 NAPA Seal I.D. 1 in. VMRS Code 065004020 Seal O.D. 1.785 in. Width .25 in |
That is where I get mine also.
your lucky with those, i tried to go to napa to get new seals for my 70's deck and the 3/4 in seals i needed would have to came from 6 different stores and they wanted to charge me $20 shipping for each piece
As an aside do you need new shaft spacers that the seal rides against? I found an ebay seller that has stainless steel ones that I'm replacing the pitted and worn ones with. they even did a custom size for the ones I needed
1450- 44A deck,QA-36 snowthrower, 42in front blade No.2 Tiller 70- 38in deck, 42 inch deck |
Thanks for the NAPA info. The main local NAPA distribution hub is not far from me and they don't even list the NOS 530484. I found an industrial supply source online at around $8 each. The order is still pending, we'll see if it actually ships.
I found that some NAPA stores wanna deal with only car stuff no small engine ,or tractor stuff. but other NAPA,s do. Depends i guess who works there.
