#21
![]() Quote:
#22
The plus side of the coil gets it power from ignition switch terminal
Check that the ign terminals are clean |
#23
![]() Quote:
When the key is in the "start" or "run" position it connects battery (12 volts) to the plus (+) terminal of the coil. So likely you have a bad key switch. |
#24
![]() Quote:
R Bedell, it's a Cub Cadet 73 I appreciate everyone's help Thank You! |
#25
AS AS TEST..........
Run a Jumper Wire from the Battery Positive Terminal to the (+) side of the Ignition Coil and see if the engine runs.
#26
Yes That is Exactly what I did & she fired right up TY
#27
Then the problem is, somewhere between the Battery & the Ignition Coil. You are loosing the 12VDC+ (bad component and/or bad wiring).
