Old 05-16-2023, 08:48 PM
Esand323 Esand323 is offline
Default Can't find new blades for my 1450
Hi,
I have a Cub Cadet 1450 Mower and I'm having trouble finding new blades. The mower is 44". I'd like to order new mulching blades. The original blades are part # 759-3402-0637. The are 15" in length and have a 3/4" hole.
Can anyone help recommend some new mulching blades? I'd prefer to not order the same ones I have now and would like to try something new. However, all of the ones I'm finding online are either too long or different hole size.
Thanks.
Old 05-17-2023, 09:06 AM
ironman's Avatar
ironman ironman is offline
If you don't mind grinding 1/8" off each end, Stens has this mulching blade...
https://www.stens.com/355-089-mulching-blade
https://www.stens.com/web-assets/med...082.1684323631
Old 05-22-2023, 08:23 AM
Are those blade holes 5/8" as on the chart reads or 3/4"?
( chart is awful small to read even after blown up)
Old 05-22-2023, 08:41 AM
The correct blade(s) are 742P3002. I can find them all over the internet.
Old 05-22-2023, 02:05 PM
ironman's Avatar
Click the link for full chart...
Old 05-23-2023, 04:18 PM
Farmall450's Avatar
Heck even CC/MTD sells them still.
Old 05-24-2023, 12:04 PM
ironman's Avatar
The OP specified "mulching" blades.
Old 05-24-2023, 11:39 PM
Thanks all for the help.
Thanks for the links.
I see the blade you linked (355-089) has a center hole of 5/8" instead of 3/4", so not sure that would work.
I do think I might be able to use a slightly larger blade though. There is about a 1/4" clearance from the edge of the blade to the mower deck.
Old 05-25-2023, 07:34 AM
The "Gator" brand of mulching blades were good. Some how they sold out or were bought out by Oregon Products (https://www.oregonproducts.com/en/products/lawn-and-garden/c/lg-p).
I am not sure that Oregon Products kept the production on the IH Cub Cadet Mower Deck Blades. If you can find them, the Gator Blades for the 44" deck was 90-957.
Old 05-25-2023, 08:26 AM
Attachment 112861
Do keep in mind the spacing between the blades has to be in consideration, as the blade tips will hit, as well as the offset of the blades from the horizontal plane.
Most times the horizontal is no concern, as it is easily compensated for by height adjustment.
That said, a blade center hole can be drilled out but one has to use a carbide drill or end mill, as a high speed drill is just about as hard as the blade material, causing much heat and as much smoke as a heap big native american poe-wow.
