Old 05-22-2023, 02:28 PM
CubbyRI CubbyRI is offline
Default What is this trans squeak???
Hi All,
Before I even do anything, I wanted to throw this out here. Driveshaft not moving so its in trans. Sounds like the front section, but not sure. Ideas?
https://youtu.be/lzwRwHQbDdI
Model 100 Dec 2020 - Running condition, has snow plow!
Model 123 Nov 2020 Hydro needs much work, or resto, building front end loader for this one
Model 100 Feb 2019 apart for total frame-off / sandblast etc resto
Model 70 Sep 2020 needs total resto and an engine, or for parts
Model 70/100 Mar 2021 buried in rust, frozen engine, got free for parts.
two spare hydro rears
"in for a penny, in for a pound!"
Old 05-22-2023, 06:06 PM
OK little update it seemed low on oil, there was inches of oil in it but not up to the hole. Wild guess I put 1 to 1.5 qt 30 weight to get it up to the hole. It smelled like gear oil but all I had was 30wt. The oil that was in there was light tan.
So I put the wheels up and ran it in gear and it seems to be quieter but still squeals when lightly letting out the clutch and I can feel a light chattering and some drag when I slowly turn the wheels in neutral. Hope the added oil helps because I really dont want to tear the differential down.
we'll see!
Old 05-22-2023, 07:37 PM
Red Dave Red Dave is online now
"Light Tan"? Sounds a lot like "Milky" to me.
Milky usually means water in the oil.
Old 05-22-2023, 07:41 PM
I get ya but in this case it was not milky, I know milky oil. It was a clearish golden color smelled like gear oil. Looked very clean, just a bit low
Old 05-23-2023, 07:48 AM
Sheared pin in the front driveshaft coupler.
If the driveshaft is not moving and something is making noise how could it be in the transmission
Check the pins in the front of the driveshaft,
Old 05-23-2023, 08:47 AM
ironman's Avatar
ironman ironman is offline
If you watch his video, he is moving the tractor by hand, apparently in neutral, without the motor running.
So he means the noise is not coming from the driveshaft or clutch.
I might suspect something with the brake puck dragging.
Old 05-23-2023, 11:24 AM
I suspected the puck brake dragging possibly. is that hard to service? I'll check youtube...
Old 05-23-2023, 01:13 PM
ironman's Avatar
The short answer is yes.
The brake disc, or puck(#1) sits in the piston (3#) which rides in a cylinder in the reduction housing.
The piston tends to get corroded or rusted in the cylinder and does not release pressure.
Does it feel like your brake is dragging?
Check that all your linkages are moving freely, especially the pin (#7) through the arm (#8) and where it goes through the holes in the reduction housing.
Old 05-23-2023, 01:18 PM
VERY COOL Iron, thanks! (Assuming it not the linkage which I'll check first as u said)
I have a creeper gear to install looks like I can do both at the same time. Hopefully the brake bore is not too rusty. If it is, whats the fix, just hone it a bit?
Old 05-23-2023, 01:51 PM
Different tractor but I think the internal brake setup is the same.
Pages 4 and 5 of this thread have some pics and info on the brake.
Follow the links from Iron Man as well for some good brake info.
https://www.onlycubcadets.net/forum/...t=59509&page=4
Ken
