On my 784, on the RH side, there is what I call a "mower depth gauge". It is riveted to the frame. It tells where your deck is, with respect to height. It goes from #1 to #8, with 8 being in the highest position. Occasionally, I have seen them on the Web for sale. I have looked in my Paper Library, as well as Cub Cadet's online lookup, and can't find a part number.
(A) what is the proper term for this part? (B) what is the part number?
indicator bracket # 9
Is there a way to find the correct location to add one of those to a machine that doesn't have it? As I recall the older machines don't have any holes predrilled or marked in the frame. I always found it handy on my Uncles 1811 and my 782 doesn't have one.
RUN IN THE RED 782 w/50c deck (red); 782 dual stick, 44c deck (y/w); 1050 w/38c deck; 1864 w/54" GT deck; 1872 project Cub Cadet Pro Z 560 L 42" power angle snowblade, #2 tiller, 2-QA42a snowthrowers, 450 thrower, #2 cart; 54" Haban blade; Brinly box blade, 48" dethatcher, moldboard plow; Agri-Fab sweeper 1200, 1863, 1864 parts machines |
Thanks Lew. Out of curiosity, how and where did you find that ??
I went here, looked up the frame and there it was on a 782
https://www.cubcadet.com/en_US/conte...rtstream.html#
I just went there. Plugged in 782, and I get the same as my original post.
I did find it under the 1811, though.
Plugging in 703-0828, here is what Cub Cadet says "where it was used"....
Bad search function from Cub Cadet.
We need someone from CC engineering who can run a proper "where-used" on their Production BOMs. Unfortunately, they might not even have them for this old stuff in searchable format.
Why Farm Half When You Can Farmall? 1282 | 44C Deck, Chains, 42" Blade, Cast Weights, 020" Over K301 * 1711 | 50C Deck, #1 Rear Rototiller w/ Extensions, Sleeve Hitch, KT17S Series II 24302 --> CH18S * 1811 | 46 GT Deck, 42" Blade, Chains, M18 Magnum, Sleeve Hitch * 1782 | 60" #375 Deck, Kubota D640 Diesel * 1862 | #450 Snowblower, M18 Magnum * 782 | Y/W KT17 Series II, Sleeve Hitch * 984 | Y/W Onan/Linamar 20HP, Sims Cab, CAT 0 3 PT w/ Rear PTO, 60" #374 Deck |
If you type "782" the Pop up menu does not list this part.
BUT..... if you type in "146-782-100" (1811) the Pop Up menu shows the part, and part number.
