A couple of hours of connecting wiring, hoses and cables, it fired right up, and sounded good. I temporarily used the exhaust from the 2206. I am fabbing up the muffler setup. It drove under its own power for the first time in a long time. The clutch worked perfectly, with no slippage, noise or chatter. There is no vibration at any RPM. It's as smooth as butter. I ran it for an hour and no oil leaks. I used the throttle cable from the 2206, using the original throttle lever from the 582. I added an oil pressure warning lamp, and modified the outer air cleaner lid to fit the engine properly.
582, 682, 782, 782D, 1282, 1050, 1210 x 2, 1711, and 1811 |
Modified a 782 muffler to mate with the 2206 pipe. Sounds great. I am waiting on heat shields from an 1863 to finish that part off.
The exhaust shields from an 1863 are on. I will remove them to paint them high heat black. I drove it for 30 minutes, and all went well. The new seat is comfortable.
Got rid of the severely dry rotted rear turf tires. The 2206 engine donor tractor had a nice pair of older Carlisle USA made Ag tires in the correct size.
New foot pad
Removed the rust, cleaned and painted the muffler shroud.
Repainted the headlight panel grille, and the lower grille
One piece at at time and it's looking better & better. Great job!
Thank you!
It's coming along very well!
I replaced the dry rotted and leaky front tires and wheels with original repainted wheels and tires from a 1989 1050.
