Old 03-08-2023, 05:47 PM
ironman's Avatar
ironman ironman is offline
These pictures are of the screw that goes into the throat of the carb. As you can see, they are 10NF32 thread by 3/8"long. There are three of them. You do not want the two positioned at 3 and 9 o'clock to be too long or they will jam the choke shaft.
Of the three carbs that I currently have access to, none of them have threads in the side holes so I cant help you there. Take the carb to a hardware store and ask a clerk to fit it up.
Old 03-08-2023, 06:22 PM
Screw,washer hd tap #8-32x3/8 That is what supposedly holds that on.
Old 03-08-2023, 11:31 PM
RustyShackleford's Avatar
RustyShackleford RustyShackleford is offline
I would get Allen head socket cap screws instead of those slotted screws they used from the factory.
File Type: jpg 82553239-6EF6-449D-A4A5-7D45FA9C8FA0.jpg (23.6 KB, 55 views)
Old 03-08-2023, 11:40 PM
LAWN BOY's Avatar
LAWN BOY LAWN BOY is offline
Default Success
I cut some screws that I had that were the right thread and width with my screw cutter. They worked.
Why would you recommend allen head socket cap screws RustyShackleford?
Thanks for the help everyone!
IH Cub Cadet 70 project, view my thread in the Kohler engines section for progress.
Old 03-08-2023, 11:47 PM
They’re just easier to install since you can pop them onto the end of the Allen key instead of weeble wobbling the slotted screw into position. When I rebuilt my K241 I replaced all of the slotted screws with socket cap screws (points & points cover, etc.). Just makes life a little bit easier.
Old 03-09-2023, 12:01 AM
LAWN BOY's Avatar
Oh, ok. Thanks for letting me know.
Old 03-09-2023, 12:02 AM
LAWN BOY's Avatar
It is explained in a different thread I posted a couple hours ago, but I am also missing my engine shroud/gas tank screws… Thanks for the help everyone with this!
