Upon finding my M18 crankcase full of fuel I decided had enough of the stock fuel pump and installed the facet 40177 fuel pump that had been ordered last fall. Now, I don't even need to use the choke on start up, just shove the throttle all the way open and starts on first turn of the crank. Much better throttle response and good idle. This new pump is rated at 1 to 2 psi and I feel more at ease knowing the crank case is not going to fill up with gas.
In case anyone was wondering. This M18 in in my 782 and is why this was posted under the IH catagory.
The KT17 Series I and II both suffered from this too..
582, 682, 782, 782D, 1282, 1050, 1210 x 2, 1711, and 1811 |
When I removed the original fuel pump diaphram, I looked for holes in it and did not see any and was curious as to how the fuel would pass down into the crank case.
A stuck needle valve will allow fuel into the crankcase as will a damaged float
I had that problem on my 682 with a kt17 series 11, every so often the float sticks open and drains the gas tank, gravity is funny like that. The easy foolproof solution is to turn off the gas at the shutoff and let engine run until it uses all the gas in the carb. Just gotta remember to turn the key off after it dies.
Also keeps cheap gas from crudding up the carb
Why Farm Half When You Can Farmall? 1282 | 44C Deck, Chains, 42" Blade, Cast Weights, 020" Over K301 * 1711 | 50C Deck, #1 Rear Rototiller w/ Extensions, Sleeve Hitch, KT17S Series II 24302 --> CH18S * 1811 | 46 GT Deck, 42" Blade, Chains, M18 Magnum, Sleeve Hitch * 1782 | 60" #375 Deck, Kubota D640 Diesel * 1862 | #450 Snowblower, M18 Magnum * 782 | Y/W KT17 Series II, Sleeve Hitch * 984 | Y/W Onan/Linamar 20HP, Sims Cab, CAT 0 3 PT w/ Rear PTO, 60" #374 Deck |
Shutting the fuel off is a good idea and I do have the shut off located just before the carb.
If you're lazy or forgetful you could install one of these.....
https://www.amazon.com/dp/B01M5IXT4D...xpY2s9dHJ1ZQ== |
