Old 01-08-2023, 09:47 PM
Postal24060 Postal24060 is offline
Default 125 hydraulic lift install and rebuild driveline.
I have been looking for a NF hydraulic lift for some time. A few weeks ago I drove 10 hours round trip and bought a running working 125 with hydraulic lift. Finally got time to remove the lift from the donor tractor and installed on my 2 owner 125 and it’s working great. Also had to do the cork seal and I figured while I had it split I would replace the rear drive coupling, the flex disc, the drive shaft, the front drive hub, and fresh filter and fluids all around. Should be good to go for a bit.
Old 01-08-2023, 10:23 PM
Tim.E's Avatar
Tim.E Tim.E is offline
Good job!! You should be good for another 40 years or so.
Now tell me about your rear tires. Are they an R14 type? What size and brand?
Cub Cadet 100 "Super" (red) show tractor
Cub Cadet 100 show tractor.
Cub Cadet 100 worker
Cub Cadet 106 refurbished/modified (red/white)
Cub Cadet 128 "refurbished"
Cub Cadet 1450 my dedicated mowing tractor
Tractors awaiting refurbishment:100 with fenders,128,73 with creeper and fenders,106,122,147,126 with creeper.
100 w/pan seat and 3 point hitch
Old 01-08-2023, 10:29 PM
They are Carlisle Versa-Turf. Cross between Ag tire and turf tire. This set is standard 23x8.50x12 for the 125
https://www.carlislebrandtires.com/o...il/versa-turf/
Old 01-08-2023, 10:36 PM
Tim.E's Avatar
Thank You. I like!
Old 01-09-2023, 06:57 AM
Looking good.
Old 01-09-2023, 05:06 PM
RoseHillFarmIHCC125 RoseHillFarmIHCC125 is offline
Those tires look great, nice job!
Old 01-09-2023, 06:09 PM
Cool, I have been looking for a lift for my 125 as well for lots of years.
You renewed my hope. And your machine looks pretty darn good also.
Ken
Old 01-09-2023, 06:39 PM
What's up on the 2 roll pins on the pump side?
Up to 534 and counting...
Old 01-09-2023, 11:27 PM
There is only 1 roll pin. There are 2 set screws on opposite side that tighten on the shaft.
Old 01-10-2023, 03:01 PM
Sergeant's Avatar
Sergeant Sergeant is offline
What ever you do, do not fill these tires with Rim Guard, as it tend to damage the Tire. Deere puts warning in their manual about it, and Deere dealers have ignored the warning. They are now finding out, the Rim Guard does something to the Radial Ply designed side walls causing, the tires to fail.
